no vapor barrier
rob1's Avatar
04-23-05, 07:19 PM   #1
rob1
no vapor barrier
Hi
I have recently purchased a 22 year old 2160sq/ft bungalow with a basement, and have come to find there is no vapor barrier in the walls or ceiling. The outside of the house was never finished with siding, is there any way to seal my house up with out having to tear apart the inside? I am scared that when I seal the outside of the house and side it there will be condensation in the walls and eventually they it may mold or rot. temperatures get as cold as -40C in winter. do you see any options for me?
I think the reason nothing has rotted out so far is that with only plywood on the exterior, the house has been able to some what breath. also the insides of the exterior walls are sheeted with 1x8 boards with 0.25 plywood and then panaling.
michiganguy's Avatar
04-29-05, 04:42 PM   #2
vapor barrier
The lack of vapor barrier on the inside of the walls shouldn't be regarded
with too much concern. It's a good idea to have it, but I wouldn't do
anything destructive to put it in there. Unless your house has some unusual
source of moisture, like a wet basement, damp crawlspace, indoor pool or
hot tub or cultivating ''pot'', you shouldn't have a moisture problem inside
the walls due to normal circumstances. Moisture problems inside walls are
usually the result of condensation. Condensation is the result of normal
amounts of humidity turning into water ( condensing ) as a result of a
temperature differential. To reduce the temp. differential inside the walls,
I would use a 1/2'' poly styrene board under the new siding your planning on.
The business of moisture getting trapped inside walls from normal interior
humidity is way overblown. You need to reduce the temperature differential
and you shouldn't have any problems. By the way, how cold is -40 C ? You
must live in Canada, we pretty much decided the old method was best in
the ''states'', thankfully, because I'm too old to relearn everthing. Best of
luck on your project.
