Insulating old "California Bungalow"
Old 06-06-05, 09:16 AM
zeynbungalow
Hi guys,
I have a 1915 bungalow where we've stripped the dining room to the studs to repair some insect damage. I figured that while it was open, I might as well insulate it. The studs are 16" on center, however because they used "real" 2*4s (ie they are two inches wide) I've got a between stud gap of about 14 1/2 inches.
I've already bought 15" batts, can I just curve them to fit or shoud I cut 1/2 an inch off the side. If I do cut it, what do you normally use as staple tabs?
The bats are R13, JM comfort therm, with the plastic sheathing.
Also, I have clap board siding. should I caulk up any gaps/cracks prior to installing the insulation, or do they provide a moisture exit.
I'm in Southern California.
Thanks for your help
Cheers
Peter
Old 06-08-05, 06:54 PM
You will not be compressing the insulation that much so I would recommend just curving them in as you described.
As far as caulking the gaps on the backside of your siding, I would recommend against it because you might trap moisture behind the siding.
Old 06-09-05, 09:48 AM
zeynbungalow
Thanks for the reply Resercon.
I've done some more checking, and it seems that the stud spacing is not equal. In several places it is down to 12 inches - so it looks like I'm gong to need to strip some of the insulation off. Is it as easy as cutting it down vertically - while making sure not to cut through the front "staple tab"?
I'm using the "comfort therm" plastic wrapped batts from JM. the plastic is perforated in places - so it looks like I'm going to need a seperate vapor barrier.
Cheers
Peter
Old 06-09-05, 07:29 PM
It will be quite difficult to cut the insulation the way you intend to. Personally I would cut clear through vertically making sure the width that I cut was a little wider than the wall cavity so that the insulation will stay in place by friction.
If there is only a few perforations, you could tape over them, but if there are several, then you might be better off using a plastic sheet for a vapor barrier.
Trackbacks are On
Pingbacks are On
Refbacks are On
