1890's home w/o Insulation
Old 09-07-05, 05:44 AM
garrett76
I live on Long Island, NY in a 1890's Victorian. continually under renovation/restoration..... NO INSULATION on outside walls......Only 3rd floor finished area, attic and roof are insulated. I have been looking into insulating, however I am not ready to rip out plaster and redo all my walls.
It has been suggested that I have "CELLULOSE" blown in. I have been reading up on this and spoke to several local people re this possble solution....
I am getting every possible suggestion as to the "VAPOR BARRIER" issue. Some actually tell me because it is an older house, not to worry (why not), while others tell me if I want to I can use the special paints that will do the job acting like a vapor barrier.
Any suggestions and recommendations short of redoing all my interior walls by replacing plaster w/ sheetrock and insulation....
Thanks. Fred
Old 09-07-05, 08:42 AM
You may find this article interesting...
http://www.joneakes.com/ca/hs/cgi-bi...hs.cgi?id=1614
Old 09-07-05, 10:58 AM
jhb
Similar situation
I have a similar problem with my 200 year old farmhouse. I am giving serious consideration it icynene (icynene.com), no vapor barrier needed. They have a pour in formula for walls. I am going to use it to insulate my crawspace.
Old 09-08-05, 10:32 AM
mrm323
Icynene is a good product, but doesn't give you much of a vapor barrier, being an open celled foam. I would look into closed cell polyurethane foams. The R-value is much higher than open celled foams and there are several companies that make it and you can even get it in kit form and do it yourself.
Trackbacks are On
Pingbacks are On
Refbacks are On
