Adding Insulation
Old 10-09-05, 04:53 AM
bardel
Adding Insulation
I recently had a 14' x 18' room addition added onto my house. The walls were insulated with R-19. The exterior will be vinyl siding with 3/8" fan fold. However, the R rating of the fan fold is only rated @ R-1.5.
I was considering adding or substituting a higher rated rigid type of insulation prior to completing the siding. Lowe’s has rigid insulation board measuring ½”, rated @ R-3.3 and 1" @ R-6.5
The windows have a built-in J channel which has a width measuring 1".
Can I add ½” rigid to the ⅜" fan fold or a full 1" without the fan fold, or would the 1" not work with the siding because of the 1" window J channel limitation?
Because of higher fuel costs, I would like to maximize the R rating.
One contractor indicated that going beyond R-19 for the walls is not cost affective, that anything beyond R-19 would not save on heating cost. What would you do?
Thanks for your reply.
Old 10-09-05, 09:37 AM
Hellrazor's Avatar
I use Tuff-R 4x8 foam, it gives the highest R value of any of the equivalent thickness foam sheets. Lowes carries that around here.
Old 10-09-05, 01:30 PM
bardel
Thanks Hellrazor for your reply. That’s just what this insulation is, super turf from Lowe’s, however, my question is... in view of possible increased utility costs, should I add the additional insulation beyond the R-19 insulation factor?
I live in Northeastern PA where the winters are quilt harsh and the summers are not usually very humid, therefore, if I decided on the additional insulation, should I use faced or unlaced; the exterior sheathing is currently covered with felt? The interior is completely finished and has faced R-19 in the walls.
Considering the 1" limitation on the window’s J Channel, would I be able to install(“squeeze”) the additional 1" of rigid insulation along with the siding into that 1" space, or should I go with a ½” rigid board by itself or in combination with the fan fold, or nothing at all?
Thanks for your expert opinion.
Old 10-10-05, 10:42 AM
bardel
Apparently, everyone is busy or doesn’t know the answer to my posed question(s). If someone knows of another site in regard to proper insulation installation techniques [boy, is that a tongue twister], I would certainly appreciate it if you could direct there as the contractors are coming tomorrow to install the siding.
Thank you in advance.
