insulation and wood shingles
1735saltbox's Avatar
11-18-05, 08:44 AM   #1
I just completed an adddition on my house which includes a cedar shingle roof on 1x4 skip sheathing. I'm getting ready to insulate the roof which has double 2x8s. I was planning to use the fiberglass batts and have 2 questions. First, do i need to do anything to insure good air circulation (i can't add any vents) other than leaving a 2" pocket just below the sheathing. Also, what should be done regarding a vapor barrier ? Thanks
Concretemasonry's Avatar
MN
11-18-05, 10:01 AM   #2
Vapor barrier toward the heated side (inside).
Ventilation helps any roof last longer.
If you are in a cold, snowy climate, you could be asking for a lot of trouble with no additional venting. You may not see leaks but you can get wet insulation that does not dry out.
Dick
11-18-05, 11:07 AM   #3
Thanks
I'll see what I can think of, maybe leave some breathing room at the fascia board
11-18-05, 11:30 AM   #4
would it make sense to put some sort of vapor barrier on the top side of the insulation as well ?
