Foam insulation under bathroom
dontrushmedon's Avatar
01-03-06, 04:38 PM   #1
We live in Michigan in an old house with a marbled bathroom floor. It's winter and the floor is cold. We have a regular old basement -- not finished. Would putting up foam insulation, between the joists under the bathroom floor help make the bathroom floor warmer? If not any suggestions? Thanks
Concretemasonry's Avatar
MN
01-03-06, 04:54 PM   #2
Insulation will help in heat loss, but the tile will still seem somewhat cold.
Materials like stone and metals have a high rate of transmission and always feel colder than the surrounding air even if the are at the same temerature. That is the reason you steel ot cast iron tub feels cold.
Dick
em69's Avatar
01-04-06, 04:21 AM   #3
As Concrete says, insulation will not really help.
If you access to the space under the bathroom, then the best solution is a heated flooring system.
I will never live without this feature in a tiled bathroom again...it is really great.
01-04-06, 06:14 AM   #4
How to put a heated floor underneath
Concrete, and Em -- thanks for the reply here's are 2 follow up questions.
1. What is the best way to put in foam board insulation under the floor, for the time being?
2. What type of floor heating systems are out there -- is it something you'd plug in (electrical)?
Thanks -- I wait your replies with bated breath(?)
em69's Avatar
01-04-06, 10:27 AM   #5
There are a few ways to do in-floor heating. You can use either hot water or electric. I personally have electric in my main bath as I did not want any future water problems if there was a leak.
Here is a UK site but it has a good diagram on how a warm water system is installed.
Select "timber" joisted and it will give you a diagram for installation
http://www.nu-heat.co.uk/index.cfm?f...floorsSelector
And there is this site:
http://www.warmzone.com/retrofit-radiant-heat.asp
