garage door insulation
Old 01-25-06, 03:13 PM
Looking to insulate my garage door with either the foil insulation or the styrofoam stuff. Any input experiences on brands, install, where to buy, etc.
thanks, charlie
Old 01-27-06, 12:31 PM
here's what I did - http://forums.audiworld.com/a6/msgs/582524.phtml
Not sure about the overall efficiency, we have a pretty mild winter here in VA
Old 01-27-06, 07:21 PM
Smokyie
I did mine last summer with styrofoam, 1 1/2" thick, and it's really made a huge difference. It was well worth the effort.
Old 01-28-06, 03:55 PM
Most codes and common sense say you should cover any exposed styrofoam in a garage for fire reasons. Sheet rock works, but it is heavy.
Dick
Old 01-30-06, 06:46 AM
doug thomas's Avatar
Fire protecting? That sounds expensive.
Are you trying to make the garage into a comfortable work area? Or do you have cold rooms around the garage? If it's a cold rooms issue, it might be cheaper to just improve on the walls around the garage.
If you are trying to make the garage into a comfortable work area, you might find out that things get pretty expensive pretty quick.
