Radiant Barrier Insulation
Old 06-08-06, 11:06 PM
Dear Sir or Madam:
I am in the process of finishing an upstairs that will
have vaulted ceilings. I am considering using
radiant barrier insulation in the vaulted ceilings and
exterior walls. Does radiant barrier insulation work well
as a stand along product or is it best to use
Fiberglass insulation as well? I live in TN.
Old 06-28-06, 10:55 AM
I would advise using both.
I have 3 bedrooms on my second floor. The Master bedroom has the vaulted ceiling. I ONLY have fiberglass insulation. I do notice that there is definitly a temperature difference compared to the other rooms. It's most noticeable in the summer months. If I knew what radiant barrier was before I had it done, I would have done it.
Old 07-05-06, 09:51 PM
Ed Imeduc's Avatar
Wink
Put foam vents to the under roof side. Then the fiberglass insulation in the roof rafters. that R/B dont work to well test show after 5 years the dust kills it out. We also put a 4 mil poly over the insulation then the drywall.
ED
