Vapour barrier to concrete wall
Hi,
Based on what I've read, I'm supposed to place a vapour barrier to the concrete wall according to http://oee.nrcan.gc.ca/residential/personal/new-home-improvement/choosing/insulation-sealing/basement/khi-inbasement.cfm?attr=4
(I'm in southern Ontario).
My questions are pretty simple
1. How do I attach the vapour barrier to the concrete? Should I be using acoustic caulking or somehow nailing/screwing the barrier to the concrete?
2. Do I apply whatever technique in 1. to the bottom edge (where the floor meets the wall) to create a perfect crease?
3. Does the vapour barrier have to start only at the group level rather than all the way to the top?
4. Seems like a LOT of insulation to put a set horizontally and then vertically between the studs. Is this really necessary?
Thanks,
Charlton
Thanks,
Charlton
Received 1 Upvote
1 Post
I like to staple it to the sill plate and just let it hang. It will be on the floor so just set the P/T 2x bottom plate right on top of it. check code up there . Here we just put a R13 in the studs upright.
ED
ED
