need advice on rigid foam insulation
abq's Avatar
09-23-06, 07:12 PM   #1
I have an older home partially constructed with cement block (hollow core blocks). The outside walls have no insulation either on the inside or on the outside under the stucco.
I just recently bought the home and the seller had a new stucco coat put on the outside without adding solid foam insulation first. A cheap and quick job for a quick sell.
So I would like to insulate the inside of the exterior cement block walls by using rigid foam insulation sheets and then cover that with sheetrock/wallboard.
I remember many years ago that it was unsafe to use rigid foam inside a house because a fire would create a toxic gas when the flame reached the foam.
So the question is this: Is there any safe rigid foam insulation for interior use? Brand name? Chemical name?
I live in Albuquerque, New Mexico.
Thanks for the help.
Concretemasonry's Avatar
MN
09-23-06, 07:17 PM   #2
The commonly available extruded polystyrene is usable, but should be covered with drywall. There may be local requirements on the required thickness (1/2" or 5/8").
You can also use a lightweight plaster (perlite?) and the thickness may be controlled by the local requirements.
Dick
Ed Imeduc's Avatar
MO
09-23-06, 07:25 PM   #3
In Fl with a cement block home They put 1X 2 P/T board on the wwall 16" on c/ then blow a cellulose insulation on the block wall that is a little wet with a glue . Then the drywall
ED
