adding insulation to existing cathedral ceiling
Old 12-06-06, 10:31 AM
I would like to add more insulation to an existing cathedral ceiling.Currently it only has R 13 and is unvented.Should I to lower the catherdral ceiling by 12" by adding 2x12 joists an add R-38 fiberglass insulation over the existing drywalled ceiling. Or should I remove the entire ceiling, vent it and add deeper joists and add the R 49 that is recommened.I would perfer not to remove the existing ceiling either way i look at it i need to add addtional deeper joists in order to leave room for the added insulation.
Old 12-06-06, 12:26 PM
I would remove the drywall, vent it then build up the studs to get the recomended insulation r-factor for your area. I think if you do not remove the existing drywall ceiling you will have moisture problems.
Trackbacks are On
Pingbacks are On
Refbacks are On
