Repairing an insulation problem under the roof
Richard904's Avatar
KS
01-22-07, 10:17 AM   #1
We bought a contemporary house built in 1994. In one area there is snow melt on the roof. In that area the roof slopes at about 30 degrees, and we have an access door to it. In that area R19 insulation is attached underneath the roof with the paper facing in. There are two areas near the edge where the insulation is missing, and this is where the snow melt takes place. Since the angle to the edge is 30 degrees, it is very difficult to get in there with roll type insulation. There are cables, air conditioning ducting, and a vent pipe that would obstruct the roll insulation. What do I do to match the currect R19 to solve this problem?
Richard904's Avatar
KS
01-23-07, 07:07 PM   #2
Spraying insulation
There must be something that can be sprayed to the underneath of the roof and rafters.
jganyard's Avatar
01-24-07, 09:04 AM   #3
How about froth-pack or fomo-foam (also tiger foam)? Those are DIY spray foam kits you can get. Kind've pricy but imagine all the air sealing you can do around the house with them.
Wirepuller38's Avatar
TN
01-24-07, 12:54 PM   #4
Insulation
Try using a long stick to push the insulation between the rafters to the area mentioned.
Ed Imeduc's Avatar
MO
01-24-07, 02:11 PM   #5
The big box stores have the blower for cellulose get some there and blow it in yourself.
Richard904's Avatar
KS
01-24-07, 03:15 PM   #6
How would blown cellulose adhere to the ceiling?
If I blow in the cellulose, it would have to fill the space from floor to the rafters far enough in that I would then have space to use the R19 roll and staple it properly to the rafters. Maybe I can get XPS, cut it to size, and since it is rigid, slide it in between the rafters.
