Insulating a Bathroom
Old 02-04-07, 05:44 AM
Question Insulating a Bathroom
What's the best way to insulate a bathroom in the northeast US? Kraft faced fiberglass, unfaced fiberglass, or unfaced with poly overlayed??? Or even foam (over fiberglass batt?) I've seen all 4 recommended. I see that Certainteed has a vapor barrier that's breathable, but there are no vendors in my area. Any and all suggestions greatly appreciated! Thanks.
Old 02-05-07, 06:42 AM
I would recommend installing insulation with a vapor barrier on any walls, ceiling and/or floor that is in direct contact with an unconditioned space. Most wall/ceiling/floor coverings for bathrooms usually qualify as vapor barriers. This is because of the high humidity usually associated with bathrooms. To control the amount of moisture in bathrooms, I strongly recommend an exhaust fan that terminates to the exterior of the structure.
