Basement insulation
Basement insulation
I had to frame away from the perimiter of one of the long walls due to the gas line/water lines that run overhead. So my top plate/bottom plate/studs sit about 4 inches away from the foundation. Including the 3 1/2 inches of depth for the 2 x 4's, I have almost 8 inches of space.
What can I do insulation wise?
Received 1 Upvote
1 Post
Lost here whats up?? But as far as the wall .You should have a 6 mil poly hanging down over the cement wall .Staple it to the sill plate. As this is below ground use just a R13 in the studs paper side to the room. A 4 mil poly over all that then the drywall .
Dont forget we are not just at your call
