HAVC duct sealing
Old 08-12-07, 08:34 AM
HAVC duct sealing
What should I use for sealing my home duct joints? Duct tape, like the famous Scotch's (3M) Duct tape, or Aluminum tape?
Thanks,
Alex
Old 08-12-07, 09:15 AM
airman.1994's Avatar
Duct seal or mastic as some call it. If it is not in an atick or crawl-space I would not waste my time or money. Their will be no savings
Old 08-12-07, 10:13 AM
nap's Avatar
nap
nap is offline
New Member
what are your duct made of?
if fiberboard, then the aluminum tape,(which sould already be on there as it is needed to manufacture the duct)
if metal duct, I believe what airman was referring to (if I understood his intent) when speaking of mastic. There is a bruch on almost paste thick material that works very well. I see it used on commercial applications all the time. It not only sticks better than the tapes you mention but it also seals better and is easier to apply.
I would look to a pro supply house. can;t remember seeing it at the home imporvemnet stores.
