best practice for applying vapor barrier tape?
Old 08-22-07, 07:32 AM
F
Hi all,
I've insulated and vapor barriered the exterior walls of my basement. I am not sure where I should use vapor barrier tape.
so far I have used it on any vertical seams where I had to overlap the vapor barrier. And also around the electrical outlets.
Do I need to apply the tape to horizontal seams along the base and top of the walls where the vapor barrier ends and the floor/roof begins.
Not sure if this makes a difference, but I won't be drywalling.
Any tips are appreciated.
Thanks.
Old 08-22-07, 06:40 PM
chandler's Avatar
Received 6 Votes on 6 Posts
What will your final wall covering be, if not drywall?
Old 08-23-07, 07:38 AM
F
for the forseeable future there will be no wall coverings. Just the poly. Am not developing the basement at this point, just insulating.
Old 08-25-07, 04:02 AM
chandler's Avatar
OK, then I would apply tape on all edges and at all intersections and around the boxes just to keep the insulation from becoming airborne and to keep the moisture at bay. And I would opt for a thicker vapor barrier than normally used, since it may be subjected to being torn. Keep a roll of tape handy in case it happens.
Old 08-25-07, 01:09 PM
F
cool thanks. That is the conclusion I was starting to come to myself.
