A-Frame insulation
Old 10-25-07, 10:01 AM
D
A-Frame insulation
I just bought an old (late 60s-early 70s) A-Frame cottage. We ripped out the old, dark, battered pre-finished paneling so we could replace it with drywall. There is no insulation in the building at all. I know you need to leave air-space in the ceiling -- but in an A-Frame, how do you decide where the wall stops and the ceiling begins? Or is there a special technique to insulating A-Frame building? The studs/joists are 2 x 6, 24 inches on center. I thought about just stuffing them full of insulation on the theory that some insulation is better than none. But would not leaving an air space for the roof create a bigger problem than not having insulation?
Thanks in advance for your input!
Curt Allen-Little
Old 10-25-07, 02:48 PM
logcabincook's Avatar
We have zero airspace in our solid wood cathedral ceilings - it goes open beams, then tonuge and groove ceiling, then 6" solid insulation, then plywood, then tar paper, then shingles. While the house is not uber-insulated, it's not bad either. So I would think stuffing the cavities you have with the best insulation you can afford would be your best bet.
Old 10-25-07, 04:13 PM
A
We have a couple of houses where we filled up a 10" space with no problems.
Old 10-30-07, 09:40 AM
H
I was just talking about this subject with my coworkers. I also live in an A-Frame and I just started researching how to insulate it.
I wanted to put up rigid insulation on the interior ceiling (which is the inside of the roof tongue & groove),and then cover it up with cedar t&g, but I was warned not to because of moisture getting trapped between the insulation and the ceiling. This moisture would then start to rot my roof from the inside out.
I work at an engineering firm where one of the departments specializes in home inspections, etc., and I want to believe them, but they also suggested googling around to see if anyone else has looked into this.
Currently there is no ridge vent at the peak, so I have a "hot roof". The roof construction is 2-1/4" pine t&g, felt, and then shingles.
Anyone have any suggestions?
Old 11-21-10, 09:32 PM
B
i have been working in construction co. ......A-Frame display systems can be very usedfull while improving our house.........
