IN
11-23-07, 08:44 PM
Should I add tyvek to house?
I have a house built in 1978 that has vinyl siding over a black fiberboard sheathing (not sure of the name of it) with fiberglass batt insulation and a plastic sheet vapor barrier then drywall. I need to pull siding off of our house repair the flashing on a dormer, Depending on the damage to the sheathing I may replace it with polystyrene sheathing or osb. My question is this, should I put tyvek over the sheathing or will this trap moisture between the drywall vapor barrier and the sheathing? thanks!
IN
11-24-07, 06:53 AM
Ok I went to tyveks website and they say its a gross water infiltration barrier, and a air infiltration barrier. It says its breatheble so I suppose it wouldn't hurt to use it over the black board sheathing or the polystyrene sheathing if I replace the blackboard.
