Is it OK to use R-30 on ext walls?
bud659's Avatar
08-24-08, 05:31 AM   #1
In my bathroom has R-13 on the exterior walls that was doubled up. The studs are deep enough to allow back-to-back depth of 2 R-13 sheets.
If I have the room, can I use R-30 on an exterior 2x4 wall? Would it be better?
TheDIYGuy's Avatar
New Member
08-25-08, 04:22 PM   #2
If your walls are 2x4 then the only insulation you can install is R-13. If you install anything thicker you will only compress the insulation and defeat it's purpose.
Are you planning on insulating from the inside or outside?
Thanks for listening.
bud659's Avatar
08-25-08, 07:10 PM   #3
from the inside but my exterior walls. i used the r-13 and is it OK that the insulation covers the electrical wire that is stapled in the wall between 2 studs ??. And I insulated all around my IC recessed lights. is this ok?
TheDIYGuy's Avatar
New Member
08-27-08, 09:11 PM   #4
Covering the wires is fine and around the lights as long as you leave a bit of room around the lights. No insulation touching or covering the lights.
