Recessed Lighting
Flyboy65's Avatar
12-20-08, 04:32 PM   #1
Recessed Lighting
How do you keep warm air from infiltrating the attic from recessed light fixtures? The ones we bought are not "air tight", but IC. (Insulation Contact).
I had to cut open the second floor ceiling, and unfortunately, cut a hole in the floor of the unused attic, since the cans extend only an inch or so above the floor of the attic.
Should I jamb some polystyrene in the joist area, and build a box of polystyrene or sheetrock above the attic floor?
The "air tight" cans are pretty spendy...
d00bs's Avatar
12-20-08, 05:54 PM   #2
Go into the attic and put cut pieces of foamboard in the bigger holes around the can if necessary and the use a can of sprayfoam to seal it all airtight. The sprayfoaming part is key.
mstevensphoto's Avatar
12-20-08, 07:24 PM   #3
I just bought airtight cans at home depot for $6 each, not so bad. note that they're not air tight if you don't use air tight trim kits.
carl1's Avatar
12-22-08, 04:04 PM   #4
I have used cut pieces of foam board to do this on my own home. Build a box around can and use the 'foam in a can' stuff to seal around it. Just make sure you provide the recessed light can with some room to dissipate heat, even though it's IC rated...say 2-3 inches around it. Then if you can, insulate on top of it with blown-in cellulose or something else. Ideally you want more than that R-5 foam board around that space where the light is. good luck, i wish i didn't have recessed lights, pain in the butt.
Flyboy65's Avatar
12-22-08, 05:07 PM   #5
Yup...I'm finding that out. But, they look nice when you're done...
