insulating attic air handlers
Old 12-22-08, 08:55 AM
K
I have 2 air handlers located in an unheated attic. both coils in the units are feed with hot water from a boiler in the basement on two seperate zones. I would like to minimize any heat loss so I was thinking of draping insulation batts over the units like a large blanket. since there is no combustion, would this be a problem?
Old 12-24-08, 11:54 AM
R
You must first check with the manufacturer of these units before doing such a thing. Even though you do not have a burner inside these air handlers, there is a fan. From my own experience when dealing with such a situation, I always opted to build a room around the air handlers inside the attic.
Old 12-24-08, 01:48 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
They will have insulation on the inside.
