DIY fiberglass blow in between studs
mayhem69's Avatar
12-02-09, 01:07 PM   #1
Hi, i need about 450 sq. ft. blown in between my studs from inside. I saw at HD and Lowes you can rent a machine for blowing in celluose. What about doing the same with fiberglass? What is involved? I am thinking about just buying a hole saw and going at it.
Bud9051's Avatar
ME
12-02-09, 01:30 PM   #2
I guess I have to ask, why fiberglass. The dense pack capabilities of cellulose work well to air seal anywhere it is used and air does move between the drywall, sheathing, and frame.
I know the larger machines can blow both, doubt if the ones I see at my box stores will do fiberglass, but ask, some have full rental services.
They also have a quantity with which you get the machine for free .
Bud
Concretemasonry's Avatar
MN
12-02-09, 02:13 PM   #3
I have the same question. Why fiberglass when you can do cellulose just as easy and get a better job in the end.
Dick
