Poly styro foamblock insulation attic access hole
Old 01-11-10, 10:55 PM
I used some all weather silicone to attach some of the polystyro block foam insulation to the topside of my attic access panel (2x2 wooden cover).
I want to put some weather stripping around the edge where the foam rests upon for some added insulation.
My question is can I add some heavier plywood to the top of styroblock insulation to get a better seal with the weather stripping without compromising the insulation value?
Thanks.
Old 01-12-10, 07:40 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Yes..it will even add a bit. You could also use less dense weatherstrip so it will compress easier..or add the plywood to the existing plywood....whatever works best for you.
