Spray foaming basement sill plate
I was thinking of using this product
https://www.sprayfoamdirect.com/prod...mart/Itemid,1/
any comments, which is better for this application (closed or open cell foam)
Or
Should I put a small amount of foam and use fiberglass to finish the job
Thanks
Or
Thanks
Closed cell would be fine on the rim joist/sill plate area. Only concerns would be temperature, currently cold, and local codes, do they require the foam (sheets or spray) to be covered with a fire barrier. Sealing and using fiberglass works, less expensive, but much slower. The jobs where I have seen the spray foam really have a wow effect and the home owners like the results.
Bud
Bud
