R-13 or R-21, that is the question??
Dellguy1971's Avatar
PA
03-27-10, 06:13 AM   #1
Hey all.
Reached the final hurdle of our insulation 'improvement', and for the final phase, I want to replace all the old wall insulation in a livable attic space which has either collapsed or been destroyed by critters (mice have way too much time on their hands!!!).
This is an older house, 1930's, so the studs are 2.75 inches deep which would only allow me to use R13 (a little compressed at that!). Is it worth me going to all the trouble of adding 2 x 4 'extensions' to each stud to allow me to gain enough depth for R21, or is the difference in the R values so negligible that all the effort is not worth it??
Would really appreciate any comments/help.
Thanks as always, these forums are a life saver!
Dellguy
Bud9051's Avatar
ME
03-27-10, 06:24 AM   #2
Hi Dellguy
If you will be heating that space, then the savings would justify increasing the insulation. Fiberglass insulation will function under minor compression, the loss occurs due to the reduced depth. A 2.75 inch wall would give you about 75% of the R-13 or R-10 and then you have to calculate the studs and EECH, you are down to R-7 or 8. Two inches of rigid foam with drywall over that is an option that uses less space and covers those studs. But padding them out works also.
Bud
Tolyn Ironhand's Avatar
MN
03-27-10, 06:58 AM   #3
I know you can get a better R-value with a spray in foam in a smaller space. Have you looked into that? Prices around me are about $2 a square foot.
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
