pipe hole insulation
Old 11-30-00, 06:45 AM
After extending a water pipe line through block, I now need to plug around the hole I made to fit the pipe through and reseal the foundation wall from daylight.
What should I be using to seal in my water pipe through that one foundation block?
Old 11-30-00, 11:40 AM
I would buy a can of insulation in a can. Owens Corning(pink panther on the can) is a good one. Squirt it in from both sides. It will expand and seal the hole. Make sure you shake it up good.
Old 12-02-00, 07:22 AM
Jack's idea is a nice fix. One small note, make sure after the foam cures cut back flush with the wall using a hacksaw blade the insulation which expanded out. Then make sure to paint the foam insulation. UV rays will quickly break down the foam if it is not protected against sunlight.
Trackbacks are On
Pingbacks are On
Refbacks are On
