Laminate flooring gets wet in morning
Every morning laminate flooring along the edge of wall gets wet and than later it drys out.....this wall is exterior wall outside of which is direct connection with external environment do you think it is condensation which is why laminate flooring gets wet in morning if yes what is the solution? Please note wall is not much wet compared laminate flooring.
Or is it possible that there is crack in concrete slab under this laminate flooring and water is seeping upwards and come on top of laminate flooring?
