insulation against exterior brick
Hi all.
I am tearing out my kitchen to the studs and want to insulate the walls. The house was built about 1920 and there is currently no insulation. Walls are plaster & lathe on 2x4 and then exterior brick.I was planning on using Roxul but need to know if it is okay to put the batts directly against the exterior brick. Is this common practice or do I have to worry about moisture wicking through the brick or mortar and wetting the insulation ? Is there some other form of insulation that would work better in this situation ?
Thanks for any advice
Hi Martin,
generally you want an air space on the inside of the brick to allow it to dry properly. I'll attach a link that goes over some of the issues.
BSD-106: Understanding Vapor Barriers — Building Science Information
Bud
Bud
Thanks Bud. Interesting reading but holy cow. Whouda thunk there would be so may variations! I should have the interior torn out buy late tomorrow and hopefully will have enough room to leave an airspace. If not ,I guess I'll just have to leave it uninsulated and keep microwaving my coffee cup before I pour one.
