How to insulate the Attic Door
Old 01-01-01, 03:06 PM
I have a pop out attic entrance door that I'd like to insulate. I've measured two pieces of unfaced R19 which will overlap slightly. How do I get it to say on the door? Glue?
Old 01-01-01, 08:12 PM
some help
Hello
If you go in and out very much you neet to secure it with a
lath on all edges use a shnort piece off copper pipe 5" at each end of the bat drill a hole in the lath use 5-1/2" screws make sure pipe gois through the insolation to the attic lid install lath and screw do not go all the way through the lid with the screws.....If this is only opened in a blue moon you can use spray adhesive add insolation and set in place....
