Framing a block wall - Is a vapor barrier needed.
Old 12-14-11, 09:13 AM
I'm remodeling my home and doing as much of the work as possible myself... Today someone pointed out I didnt put up a vapor barrier up before placing insulation in the framing I built over block walls (in my kitchen).
Is that necessary? And if so, what would be the cheapest, easiest way to do that. Keep in mind the framing is already in place.
Also, the framing is about a half inch from the block wall at the furthest parts due to getting the new construction level.
Id appreciate any input... thanks!
Old 12-14-11, 11:29 AM
B
Received 47 Upvotes on 43 Posts
There is more to it than just not needing a vapor barrier. If the block wall is exposed to soil or the weather it can transfer moisture to the inside. From there it should not be in contact with anything mold can feed on. At the bottom where the wall or floor has to be in contact with the concrete, you need to use a treated wood product. Now, that's just one rendition what you might be required to do. The rules you need to follow are issued by your local code department and yes, they do vary.
I'll add a link from the building science group to give you a background.
BSD-106: Understanding Vapor Barriers — Building Science Information
and: http://www.eere.energy.gov/buildings...s/db/35017.pdf
Bud
Old 12-14-11, 02:12 PM
I should have mentioned this is an above ground structure. My foyer is built the same way, but thats finished with plaster and painted (they were added at some point and built with cinder block walls).
So the walls meet the ground, but theres a crawlspace under each of these rooms, separating them from the ground. And the outside is vinyl siding.
Old 12-14-11, 02:30 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
As Bud said, the vapor barrier will go on the warm side of the studs. You want the back side of the studs and wall to breathe. Your kraft facing on the insulation is considered a vapor barrier....not a great one, but it's there.
Old 12-14-11, 04:40 PM
Chandler,
Sounds like your saying the current setup is okay... Theres room between the block wall and framing and the paper side of the insulation is facing the interior.
I had someone suggest there should also be a vapor barrier in the space between the block and framing too, as to keep moisture out of the insulation. And I figured the only way that could be done well would be to paint the block with something...
So am I alright the way it is?
