Insulation Above Carport
Old 12-28-11, 07:00 AM
Question Insulation Above Carport
The roof and attic on my ranch home extends all the way above our carport. The ceiling of this carport is soffit/fascia with the usual vent holes. The room adjacent to this carport is always much colder than the other rooms of the house.
Can I insulate the attic directly above this carport? I am under the impression that covering those vent holes in the carport ceiling will somehow cause damage, or moisture build-up.
So essentially all the cold or warm air comes up through those vent holes in the carport and effects the temperature of the adjacent spare room.
Old 12-28-11, 08:02 AM
jonnymo,
in the attic above both, is there a wall between the attics? Since fumes from the carport can be pulled up into that carport attic, it would be important and code to have an approved fire break between those spaces.
Now, if there is a wall with proper drywall/fire barrier (and I'm not an expert on this) then the only areas to be concerned with would be the ceiling above the cold room and the wall between the car port and the house. If there is a basement, the rim joist might need attention as well.
Bud
Old 12-28-11, 08:13 AM
So you have an enclosed ceiling above your carport?
Old 12-28-11, 09:11 AM
Bud,
There is an outside wall sperating the room from the carport.
Mitch,
The ceiling above carport is enclosed. If you are in my attic, joists go all the way over the carport, and there is room for more batting. I'm just hesitant to put more in because it would be directly over those ventiation holes.
I'm thinking that adding insulation would make that room warmer.
Old 12-28-11, 09:29 AM
Still not sure if the attic over the carport is open to the attic over the house. If not, no need to insulate over the car port. If that carport attic is open to the house, then it needs an approved wall, but still no insulation above the port.
Bud
Old 12-28-11, 09:36 AM
There are baffles you can install to maintain the roof ventilation so the insulation you add does not cover them.
Based on your description, I think some insulation might help but it's hard to say.
Old 12-28-11, 10:19 AM
Insulation Over Carport
Bud,
It took me a while, but now I understand your question. Yes, the attic over carport is open to the rest of the attic. One could walk from one end of the attic to the other. There is no break, like a wall.
Old 12-28-11, 10:25 AM
How's the insulation above the living spaces? I would think that would be a lot more important than what's over the carport.
Old 12-28-11, 10:31 AM
Mitch,
Well now, the insulation over the living space could use another layer. However, as much as I like to do home improvement, croutching and soft stepping around my attic is not a project I want to do myself. I've considered renting a blow in machine, or hiring the job out. I guess if I were careful, and took my time, I could avoid falling through the ceiling.
Old 12-28-11, 11:47 AM
There should be a fire wall between the carport attic and the house attic to prevent Carbon Monoxide exhaust fumes from being pulled into the attic above the living space. Also to limit the spread of a fire. Once that is isolated, then there would be no need for insulation over the carport.
What we actually need to consider is the insulation and air sealing needed in the house to warm up the cold spots. It may also be a heat delivery problem.
Bud
