How to correctly insulate this bathroom situation
jasesun23's Avatar
NY
05-03-12, 05:50 AM   #1
My bathroom faces the back of my house. Its on the second floor and they way the house was built the first floor has eaves. Pics attached. With the bathroom gutted I have access to the eaves. I removed old insulation in the floor and the walls. How should this Eave (believe thats what it is called be insulated). From what I can tell there is no venting in the eaves. No soffit vents. Hopefully the pics will give a better idea.
Pic1 - Outside of house to understand what I mean by eaves
Pic2 - bathroom wall facing exterior of house
Pic3 - shows old fiberglass insulation stuffed in the corners
Pic4- shows one slot/corner I removed the insulation from
jasesun23's Avatar
NY
05-03-12, 06:04 AM   #2
After correctly insulating the eaves I was wondering if I could insulate the walls this way. Could I cut some .5" polyiso foam to put up on the walls. Than add R13 fiberglass insulation on top of that (the kraft paper kind). I like the idea of the rigid foam to prevent air drafts? I'm concerned that the polyiso is a vapor barrier and the kraft fiberglass insulation is also one.
bish80's Avatar
NY
05-04-12, 09:43 PM   #3
I would not use the ridig, it has lousy R valve and is expensive. Last year I bought a roll of R-15 kraft at depot. It is as tight as a frog butt, although the foam stuff looks cool. As far as the eaves, just don't do the roof.
You are correct about the the double vapor barrier-not good.
