New home build - when to add insulation?
Old 08-30-12, 10:35 PM
T
On a new home build, do you add the insulation before or after the electrical wires are added? What about the HVAC - does the insulation go before or after all the HVAC ducting is installed?
Old 08-30-12, 11:56 PM
F
Received 39 Upvotes on 31 Posts
Generally after installation of all electrical and ductwork but there may be some locations that need insulation prior to the duct or wiring because it will be inaccessible later.
Old 08-31-12, 04:16 AM
B
Received 47 Upvotes on 43 Posts
Air sealing and insulation are integrated throughout the construction project. Headers often get a layer of rigid foam. Corners and "t's" that will not be accessible have to be insulated before the sheathing. Even some drywall that is needed as to sir seal goes in with the framing. HVAC ducts all need to be air sealed as they are installed.
As Furd said, the insulation contractor shows up after plumbing, electrical, and HVAC, as when they are done it is best to not disturb their work.
Bud
Old 08-31-12, 06:50 AM
F
Thanks, Bud. Hard for me to remember it all.
Old 09-13-12, 08:24 AM
B
Keep in mind that the electrical inspector needs view the installation PRIOR to the insulation being installed in most areas
