Insulating Basement
Old 11-20-12, 06:24 AM
T
Insulating Basement
My home is 3 years old with unfinished basement. I am going to finish the basement installing XPS foam insulation on the concrete walls followed by framing, insulation and drywall. I know there is a lot of debate about foam insulation and vapor barriers etc. I have already decided upon this plan. However I have one question. If the basement shows no sign of water (no leaks and I did the plastic on wall for moisture test) should I use a sealing paint on the walls prior or not?
Old 11-20-12, 07:00 AM
Received 1,276 Upvotes on 1,215 Posts
Sealing paint on the walls is a waste anytime, IMO. Water infiltration, if it exists, is best stopped from the outside, not by a paint after it's already 95% of the way through.
Old 11-20-12, 07:21 AM
Halton's Avatar
yep....plus the paint does nothing to stop condensation.....which should be your priority.
If possible buy foam boards that have ship-lap edges.....and use something like a PL-300 adhesive.
Run a bead and completely seal all the seams and even tape the joints with Tuck Tape.
