Insulate basement wall or in frame?
Old 05-22-13, 07:03 AM
I'm doing some research but reading in circles, can anyone help?
I've read a lot of posts and obviously everyone is in a different location and home construction. I'm in Northern NJ. My basement wall is pictured, it has a waterproofing membrane on the block that runs into a weeping drain system into a sump pump.
I'm going to frame the wall up against this membrane. Can I use Roxul in the frame and leave the concrete wall as is?
And/Or I spray foam the rim joist to seal them Or maybe the Rim joist and block down to the membrane?
Does anyone have an opinion on that?
Old 05-22-13, 07:11 AM
The attachment failed. Here is the picture-
Old 05-28-13, 03:52 PM
Hello, are you still around?
Find your Zone, either 4 or 5; Chapter 11 - Energy Efficiency
Find basement insulation requirement, read footnote "c"; Chapter 11 - Energy Efficiency
Frame a wood wall on 1" XPS (prevent thermal/air/capillary wicking) after gluing 1" XPS to the concrete and membrane plastic (that would transfer CMU temps across them); IRC FAQ: Insulating Sheathing Vapor Retarder Requirements — Building Science Information
Pressure-Treated Sill Plates and the Building Code | GreenBuildingAdvisor.com
You could also skip the f.b. on the membrane as it is below grade (IMHO- not me) and temps are colder above ground and 3' below to warrant it. Figs. 26, 27; http://www.buildingscience.com/docum...sure-guideline
Use (3-1/2") Roxul in a 2x4 wall with 5-1/2" Roxul to fill cavity above the membrane; touching the f.b.- no air gaps; https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
XPS and canned foam the rim; http://www.buildingscience.com/docum...l_seal_rev.pdf
ADA the drywall; Info-401: Air Barriers
Gary
