Insulation
's Avatar
02-19-01, 10:10 AM   #1
I am preparing to remodel an attic space. I am wondering where I can find out what R-value is required in my rafters, the thickness of insulation and then what space I need to accomodate the insulation and the foam flexi venting?
lefty's Avatar
WA
02-20-01, 03:52 AM   #2
Check with your local bldg. dept. They can tell you the minimum amount (R-value) of insulation required for your area. That will tell you the minimum thickness. They can also explain the ventilation issue to you.
