Insulating Pole Barn
Old 10-20-13, 11:30 AM
H
Smile Insulating Pole Barn
Have a 25' x 25' pole barn that is away from my house....live in Michigan..so it gets cold out there in the winter...the 2x4s are laid Horizontal...have been thinking of using owens corning 1 1/2" x4x8 sheets cut to lay in the space between 2x4s..then put 1/2" plywood over that....it would be quicker that studding in the walls and using rolled insulation...am useing a electric heater, cause am not comfortable using any thing else with lawn mowers and such stored in there......am opened to all ideas...
Old 10-20-13, 11:54 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
What is the spacing of your 2x4's and what is your external covering? If they are 16" oc, I would use Roxul and cover it with the plywood. Far superior in R rating than the 1 1/2" foam.
Old 10-29-13, 07:05 AM
H
insulating pole barn
have been checking market on prices.....am going to go with 2x4's....stud the walls and use rolled insulation...will put 1/2x4x8 plywood in places i will hang idems and osb boards in rest...not cheap which ever way...
