Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Insulation, Radiant and Vapor Barriers
Reload this Page >
Is it inefficient to have ventilation in your attic?
Old 12-17-13, 04:51 PM
O
Hi
I have a 1950s double brick house in Toronto Canada. Our attic has barely any insulation which i'm about to rectify. I did notice that there's a ventilation hole in the attic roof, one of those vents that twirls to let the hot air out.
I know this has a point, to prevent hot high pressure air building up in the summer. However it's now winter and there's definitely no hot air building up in there? So what i'm wondering is it in efficient to have this system? Can i close that vent during winter? Is there a better way to set up the attic to avoid heat loss in winter?
cheers
oman
Old 12-17-13, 05:10 PM
O
so a quick google solves my problem
Improving Attic Ventilation | Ventilation | Plumbing, HVAC & Electrical | This Old House
looks like i need the ventilation to let out moist air. On top more research and sealing those attic floor spots (lights)
Old 12-17-13, 05:58 PM
B
Received 47 Upvotes on 43 Posts
You are on the right track. Air sealing and then lots of insulation. The roof over our home is just there for protection from the elements and not to retain the heat escaping through our ceiling. Good ventilation removes any moisture that sneaks through the structure and any solar heat to prevent ice dams. Here is a link on air sealing to help you find those leaks.
http://www.efficiencyvermont.com/ste...ide_062507.pdf
Bud
