Attic Vertical walls:Insulate to great room
Old 12-19-13, 11:59 AM
biketrax's Avatar
Received 4 Upvotes on 4 Posts
Area I am talking about is adjacent to our living dinning room. Versus crawl space in uninsulated attic
I have a small vertical area (cross section) across the attic. In which the (Very) older fibreglass is basically falling off and some is just missing. I was considering installing rigid Styrofoam insulation instead of the standard fibreglass. I would be able to install a very thick fibreglass versus the rigid foam.
I would like to hear when one works better than the other, when you have the option and the choice of either one?
thanks for all suggestions
Old 12-19-13, 02:53 PM
B
Received 47 Upvotes on 43 Posts
In some jurisdictions they will require you to cover the rigid foam with a fire barrier, ie drywall. Still a lot of detailing to fill every gap.
Fiberglass also needs to be covered to prevent air currents. High density fiberglass or better, Roxul will reduce that problem.
Covering is always desirable as it improves performance and helps to keep the stray rodent out. On the cold side be sure any covering is not a vapor barrier.
Bud
Old 12-20-13, 05:40 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
I would install Roxul there.
