Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Insulation, Radiant and Vapor Barriers
Reload this Page >
can you place rock wool insulation around hot water radiator pipes
Old 02-01-14, 08:32 PM
I had an energy audit recently and one thing the guy said was to insulate the header space between the joists in the basement. I started doing that tonight as i had some spare R14 rock wool insulation.
However one section of the joists has my hot water radiator pipes (2" diameter) running up around them. I wanted to know if it's ok to snuggly fit the insulation bats around these pipes. I believe the pipes would get to temperatures around 70oC
I worried there might be a fire risk as there is with chimneys.
thanks
oman
Old 02-02-14, 10:21 AM
It is fine to place rock wool in that area. Rock wool is non-combustible and like other types of mineral wool is also molded into shapes designed to insulate mechanical system piping.
Old 02-02-14, 07:41 PM
cheers, as i posted that i started to think i was being overly worried, given that you buy that foam insulation for the hot water pipes
oman
