batt insulation for 18" rafters...
Old 03-04-01, 04:12 PM
Guest
Talking
Have an 85 year old house in need of immediate attic re-insulation. Only problem is that the rafters are 18" not 15 or 23. I'm wondering if anyone sells that size, I hate to think of cutting that many batts down to size, it's a large attic. I'm not interested in loose, blow in insulation at all. Thanks for any help you can provide.
Old 03-04-01, 07:42 PM
josh1
insulation
have you considered running the batts perpindicular to the rafters rather than parallel if there is enough height to do so
hope this helps-----josh
Old 03-05-01, 03:15 PM
L
Received 1 Upvote on 1 Post
You aren't going to find 18" wide batts. Choices are to either do a lot of cutting, or do it the easy way and blow it. Not sure why you ruled that option out, but it's your time and money -- spend it as you please.
