Basement Finish
atwoodkid's Avatar
03-05-01, 07:50 AM   #1
atwoodkid
Hi I'm buying a new house with a full basement that I want to finish. My question is the home comes with the heavy vinyl insulation on the concrete walls. Ceiling is 8' so I want to use a 2x2 frame for the exterior walls. Problem is I think I need a horizonatal cross piece that I've been told I can fasten into the wall. My concern is that the insulation will be compressed and I'll loose the insulating value. Ideas would be appreciated.
lefty's Avatar
WA
03-05-01, 03:00 PM   #2
What will you be covering the 2X2's with? Paneling and sheetrock? If so, you won't need any horizontal blocking between the 2X2's.
atwoodkid's Avatar
03-06-01, 11:46 AM   #3
atwoodkid
Thanks Lefty, I'm planning on using 1/2" wallboard so didn't know if I needed to better support the 2x2's. Do you think I'm making a mistake (going cheap) by using the 2x2 rather than a 2x4. Not sure how much cheaper it would be.
