Matching insulation and vapor barrier
Old 04-10-14, 06:46 PM
P
I had a leak, we got a new roof. I cut the drywall larger for access. Question is now that vapor barrier I patched it a bit beciase it was torn. Is that ok?
Also since the insulation was torn out can I just put in some matching insulation where it torn out?do I need to seal them together ?
Any drywall tips?
Size:  30.1 KBName:  image.jpg
Old 04-10-14, 07:21 PM
Tolyn Ironhand's Avatar
Received 914 Upvotes on 772 Posts
Reinstall the vapor barrier as best you can. If you can, overlap the new and old poly and tape the seams.
