Radiant barrier (should I) ????
Old 05-09-14, 05:17 AM
I came across this item. . it covers the attic ceiling. Doesn't that prevent air from getting to the ceiling of the attic and not allow it to breath therefore promoting mold??
Reduce attic heat - Install Enerflex radiant barrier attic foil insulation - YouTube
Old 05-09-14, 05:27 AM
Old 05-09-14, 06:12 AM
B
Received 47 Upvotes on 43 Posts
If you search the forum this topic has been beaten to death. Bottom line, the only areas that should consider a radiant barrier are in the deep south with a very hot climate and ducts and ac equipment in the attic. In all other locations, lots of insulation and very good air sealing are a proven solution.
Bud
