Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Insulation, Radiant and Vapor Barriers
Reload this Page >
should i replace wool insulation above porch with spray foam?
Old 07-04-14, 06:47 PM
O
Hi All,
I wondered if someone might share some wisdom. I'm getting some insulation done and i thought they should also tackle the ceiling of the porch which my master bedroom overhangs. I'd initially thought there wasn't much insulation up there when i poked my eye through the light socket. However, after removing some of the panelling it seems theres between 2-3 or even 4" of wool insulation (not rockwool; house is old).
From this link wool apparently has R9 per 2.36 inch or R3.8 / inch, spray foam has around R6/inch and i think that might be on the high side.
So if i had 3" wool, R11.4, i'd need at least 2" of spray foam to even equate the wool. I'm not sure what would be a common thickness to put under a porch.
Then on top of all that there's the removal cost of the old materials and most likely there would be a cost to replace the porch ceiling.
Would other people go to the trouble or would they just leave it? I guess it's personal but i'm starting to think it's not worth it.
thanks again
oman
Old 07-05-14, 04:22 AM
B
Received 47 Upvotes on 43 Posts
Are you having heating/comfort issues in the bedroom above? In addition to insulation, air sealing is very important. Foam accomplishes both, but drywall is also a good air barrier if all penetrations are sealed, like that light box you mentioned.
As for R-value, R-6o would be a minimum in my opinion. Code minimum is probably R-49, but floors are often hard to keep warm with a cold space below.
Bud
Old 07-05-14, 05:31 PM
O
Thanks Bud,
The cold isn't an issue in the room above, mainly because the radiator is too big / isn't balanced in that room. There is air leakage between the bricks though, coming out through cracks in the plaster. But i think that is from holes in the motor which i've noticed around the outside.
thanks for the advice
oman
Old 07-06-14, 03:52 AM
B
Bricks will often have a gap behind them to help with drying. Just mentioning that so you don't seal up a hole that was put there intentionally. Brick can be fussy.
Bud
Old 07-06-14, 01:55 PM
D
Received 1 Upvote on 1 Post
How big are the floor joists? I would probably just fill the rest with dense pack cellulose. R-25 is the recommendation for a floor. These recommendations are really for new construction. You do the best you can when retrofitting older homes. Air sealing can have a huge impact on your energy efficiency.
