ADDING INSULATION TO ATTIC
Old 03-15-01, 09:25 AM
Exclamation
I WOULD LIKE TO ADD MORE INSULATION TO MY ATTIC.
I LIVE IN LOUISIANA AND AT THIS TIME MY ATTIC HAS 6" THICK KRAFT FACED INSULATION.
I WOULD LIKE TO ADD MORE AND MY QUESTION IS :
CAN I ADD ANOTHER LAYER ON TOP THAT HAS A KRAFT FACE ON IT AND SINCE THE OTHER FACE IS BASICALLY AGAINST THE CEILING CAN I INSTALL THIS FACE SO IT FACES UP INTO THE ATTIC.
WOULD THIS CAUSE A MOISTURE PROBLEM?
Old 03-15-01, 01:47 PM
Exclamation
JMGray,
Dont Do IT!
Use unfaced insulation to go on top of the existing insulation.
Attics should never have 2 vapor barriers in the attic.
Go as thick as you want, go what ever direction you want, but no vapor barrier.
Best regards,
lvader
