Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Insulation, Radiant and Vapor Barriers
Reload this Page >
Can fiberglass insulation touch aluminium dryer pipe?
Old 02-22-15, 01:07 PM
SBI
SBI is offline
Aluminum vent pipes get much hotter to touch than flexible vents. Can they touch fiberglass insulation?
Thanks.
Old 02-22-15, 01:11 PM
XSleeper's Avatar
Received 1,975 Upvotes on 1,771 Posts
Yes. If dryer vents were a combustion hazard, they would be required to be double walled.
Old 02-22-15, 01:13 PM
SBI
SBI is offline
Got you. Thank you XSleeper!
Old 02-23-15, 06:38 AM
Received 1 Upvote on 1 Post
Should not be using aluminum in the first place.
That would melt through in seconds if there was a dryer fire.
Use solid galvanized pipe instead.
Old 02-23-15, 08:16 AM
XSleeper's Avatar
Aluminum is allowable by code. (504.2) Even flexible aluminum, provided it meets the standards set out in the code. (603.4)
