Has anyone blown insulation under a floor?
Old 12-11-15, 08:39 AM
F
I have a walk up attic with a 4x8 t&g sub floor. I would like to get some insulation under the floor. It measures 28' x 28', and I have 2' access on either side. I have seen where a person drilled holes in the floor and used the nozzle to fill his floor cavities and am thinking maybe trying this option if I cannot shove the hose under the floor from the sides. Anyone have any experience with this or advice? Thanks
Old 12-11-15, 02:02 PM
Received 129 Upvotes on 114 Posts
How wide are these joist?
Reason I ask is far more often then not that attic was never intended for storage and never should have had a floor in the first place.
In VA there should be a bare minimum of R-38 to R-60 of insulation in that attic, that's about 12".
https://www.energystar.gov/index.cfm...sulation_table
Old 12-13-15, 06:59 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Aside from the structural adversities mentioned, you may encounter perlins between the joists which would make it impossible to send insulation from side to side without a gap. Try sending a fish tape across the span to see if it hits an obstruction. If so, you won't be able to do a complete job.
Unless you are able to add unlofted R38+ to the attic, what you will encounter will be inefficient in the long run.
Old 12-13-15, 03:38 PM
C
Received 1 Upvote on 1 Post
Why can't you cut a 2' wide section of floor and blow from the middle to both sides?
