Seams in xps
Old 04-07-16, 09:27 PM
H
Seams in xps
What is the best way for sealing seams in xps. Spray foam or tape?
What tape will stick to the dow blue? I have heard tyvek but others said it fell off.
Thanks
Old 04-07-16, 09:37 PM
XSleeper's Avatar
Received 1,977 Upvotes on 1,772 Posts
Dow Weathermate tape. The wider the better.
Old 04-12-16, 07:08 PM
H
Spray foam seams
I put up 2in xps layer vertically, seams stagered tounge and groove. I then foamed these seams with great stuff. I then applied 1 in xps vertically stagered seams. I still have some cans of foam around, can I just run a line down each seam instead of the tape?
Old 04-12-16, 08:24 PM
C
Received 184 Upvotes on 150 Posts
Should be OK. You just want to stop any air flow through the seam.
