Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Insulation, Radiant and Vapor Barriers
Reload this Page >
I know it'll be ugly but need to temporarily board up a window
Old 06-21-17, 06:21 AM
I'll be boarding from the inside since this is not for security purposes but rather insulation purposes.
What is the lightest weight material that provides the most insulation, dryboard?
Old 06-21-17, 07:39 AM
Rigid foam is what's coming to my mind.
Old 06-21-17, 08:56 AM
Many big box home centers only stock 1/2" thick foam but if you check with a lumber yard they may have thicker. My local Lowes only carries 1/2" thick but my local, independent lumber yard stocks up to 2" thick.
Old 06-21-17, 09:01 AM
Hi Michael. Covering the inside with rigid foam can be a problem with some windows because of their solar properties. it traps too much heat. if plain glass single or double pane it should be fine.
Since windows are such a poor insulator a major improvement can be achieved with just 1" of standard pink or blue foam board (r-5 per inch). Using polyisocyanurate at R-6.5 per inch is a bit better and usually comes with a foil face. I would leave the shinny side to the inside and perhaps paint the outward side white.
Bud
